ASRPRO-Plus开发板
板子基本介绍
本例实验的WS2812B模块:
本例实验的WS2812B模块的电原理图
本例实验采用板载三位独立按键,可以搭配实现各种相关的功能。
【花雕动手做】实验五十四:测试GPIO口中断和语音来控制继电器与屏幕背光
- WS2812 ASR_WS2812_27(27);
- ASR_WS2812_27.pixel_set_all_color(0,0,0);
- ASR_WS2812_27.pixel_show();
- case NULL:
- digitalWrite(28,1);
- case 4:
- digitalWrite(28,0);
- case 5:
- digitalWrite(21,1);
- case 6:
- digitalWrite(21,0);
- void GPIO0_irq(){
- //中断里不能播放语音,要尽短时间停留在中断
- Clear_GPIO_irq(4);
- while (!(digitalRead(4))) {
- pinMode(4,input);
- pinMode(18,input);
- dpmu_set_adio_reuse(PC2,DIGITAL_MODE);
- dpmu_set_io_pull(pinToFun[18],DPMU_IO_PULL_UP);
- setPinFun(18,SECOND_FUNCTION);
- pinMode(19,input);
- dpmu_set_adio_reuse(PC3,DIGITAL_MODE);
- dpmu_set_io_pull(pinToFun[19],DPMU_IO_PULL_UP);
- setPinFun(19,SECOND_FUNCTION);
- if(!(digitalRead(19))){
- enter_wakeup(5000);
- //{ID:500,keyword:"命令词",ASR:"耍接官",ASRTO:"按键打开继电器"}
- play_audio(500);
- if(!(digitalRead(18))){
- //{ID:501,keyword:"命令词",ASR:"接耍官",ASRTO:"按键打开彩屏背光"}
- delay(100);
- //{speak:小蝶-清新女声,vol:16,speed:10,platform:haohaodada}
- //{ID:3,keyword:"命令词",ASR:"打开继电器",ASRTO:"好的,马上打开继电器"}
- //{ID:4,keyword:"命令词",ASR:"关闭继电器",ASRTO:"好的,马上关闭继电器"}
- //{ID:5,keyword:"命令词",ASR:"打开彩屏背光",ASRTO:"好的马上执行"}
- //{ID:6,keyword:"命令词",ASR:"关闭彩屏背光",ASRTO:"好的马上执行"}
- pinMode(28,output);
- setPinFun(28,FIRST_FUNCTION);
- pinMode(21,output);
- setPinFun(21,SECOND_FUNCTION);
- pinMode(4,input);
- Set_GPIO_irq(4,down_edges_trigger,GPIO0_irq);
